I have a question regarding the login procedure.
I want to run wincc oa automatically for test purposes and I am not able to override the login procedure (avoided or fill it automatically)
Is there any possibility or alternative?
Thanks you
Login barrier for test purpose
Re: Login barrier for test purpose
If you define a username and password in the config file or as startup parameter a manager will be running with this user account.
For tests with a UI there is no need to always use the login panel. You can also start the UI with the panel you want to test.
When talking about using the login panel you can probably use SSO (Single Sign On). If SSO is activated the user logged on to the operating system is automatically used.
For details please have a look at the WinCC OA Documentation.
