How to move panel by mouse without title bar
vy.nguyenthanh@biendongco.vn
Post by vy.nguyenthanh@biendongco.vn »
I only move a panel by mouse if that panel has title bar. Do you have any solution to move a panel without title bar? And how to change the displayed text on title bar.
gschijndel
Re: How to move panel by mouse without title bar
Post by gschijndel »
vy.nguyenthanh@biendongco.vn wrote: ↑ Fri Nov 15, 2019 3:03 pmDo you have any solution to move a panel without title bar?
You could use the following:
The function 'moveModule'
The property 'windowFrameGeometry'
The property 'windowGeometry'
vy.nguyenthanh@biendongco.vn wrote: ↑ Fri Nov 15, 2019 3:03 pmAnd how to change the displayed text on title bar.
By default the name of the panel is shown in the title bar. Or the function 'setWindowTitle' can be used.
Thank you for your support but your first suggestions doesn't work in my case. I'd like to move my faceplate without using title bar. It means that when users drag the faceplate by their mouse then the faceplate is moved according to the coordinates of the mouse.
Moving the panel by mouse when clicking on the title bar is a functionality of the window manager of the operating system, this is not a part of WinCC OA.
Why do you want to hide the title bar?
I want to hide the title bar to beautify my designed faceplate.
dwright
Post by dwright »
I understand that this is an old topic but I have a solution that works in Windows.
1. Press [Alt] + [Space] to bring up a menu with options like "Restore", "Move", "Size", "Minimize", etc
2. Press the down arrow to select "Move"
3. Press [Enter]
4. Press any arrow key. The window is now "attached" to you mouse cursor
5. Use your mouse to move the window to the desired location and click the left button on the mouse to drop it.
