Circular dependency
uxout
Circular dependency
Post by uxout »
Hello !
Here is the description of my problem :
I have 3 classes on distinct file for each one :
- classA.ctl
#uses "classB"
class classA {
	classB b;
- classB.ctl
#uses "classC"
class classB {
	classC c;
- classC.ctl
#uses "classA"
class classC {
	classA a;
And then when I use one of these classes, there is an error :
CTRL, WARNING,    81, Syntax error, D:\WinCC_OA_Proj\FREJUSM3\scripts\libs\classC.ctl,   Line: 3
  classA a;
CTRL, WARNING,    81, Syntax error, D:\WinCC_OA_Proj\FREJUSM3\scripts\libs\classB.ctl,   Line: 3
class classB {
CTRL, WARNING,    81, Syntax error, D:\WinCC_OA_Proj\FREJUSM3\scripts\libs\classA.ctl,   Line: 3
class classA {
CTRL, WARNING,    81, Syntax error, D:\WinCC_OA_Proj\FREJUSM3\scripts\class.ctl,   Line: 2
#uses "classB"
This problem is known as circular dependency and it is resolved in C++ by using forward declaration, but it is not possible with WinCC OA 3.17.
Is there a smart way to solve this ?
amichon
Re: Circular dependency
Post by amichon »
Hi uxout ;)
Did you try with shared pointers ?
class A
  public shared_ptr<void> ref;
class C
main()
 shared_ptr<A> a = new A();
 shared_ptr<C> c = new C();
 a.ref = c;
 c.ref = a;
uxout
Post by uxout »
Hello amichon :D
Well that's not what I expected because you loose class reference but that's a point to look.
Maybe there is no correct solution and I should avoid this situation by doing code redesign.
Thanks anyway !
