Hi.
I'm making EWO Widget.
I want to contol winccoa dp in the EWO.
How can i control winccoa dp in the EWO?
thanks your reply.
How can i control dp in ewo widget>
Re: How can i control dp in ewo widget>
What is meant with "control WinCC OA dp" in detail?
Which WinCC OA version is your question related to?
If you need assistance in implementing an EWO please get in contact with your common WinCC OA support.
- sadltkdguq
I am not good at English, so please understand.
I want to Know how to read, write dp on EWO I made
For example,
dpSet, dpGet, dpConnect...
I want to use these function on my EWO
thanks for your relpy
For example,
From my my point of view an EWO cannot deal with WinCC OA ctrl functions.
If you want to implement an EWO you have to define functions which can interact with WinCC OA. e.g. setting a color.
The WinCC OA functions must be called in WinCC OA ctrl scripts when then calls the functions provided by the EWO.
- sadltkdguq
Thank you for your reply
