WinCC OA RPMs and Dependencies
winthrop.polk
Post by winthrop.polk »
I spent days researching, but it isn't clear... what I know is that when I follow the installation instructions for WinCC OA 3.16 I have many missing nested depend.
Basically I need to know where to get the dependencies for the current version of 3.16 p28, and I need to know how to keep them updated explicitly and clearly.
I am on a secured network, we use satellite server but no external repos, all are internal. I can get the RPMs to our own satellite server to distribution around our industrial site, but I need a list and links... or something... what am I missing?
Example of perceived issue:
- libminizip.so.1()(64bit) is supposedly required
- there are no RH RPMs that provide this, minizip does.... why is this the dependency and not minizip?
Error: Package: WinCC_OA_3.16-base-rhel-0-28.x86_64 (snapshot)
           Requires: libhyphen.so.0()(64bit)
           Requires: SDL
           Requires: libgstapp-1.0.so.0()(64bit)
Error: Package: WinCC_OA_3.16-api-rhel-0-28.x86_64 (snapshot)
           Requires: zlib-devel
           Requires: /bin/csh
Error: Package: WinCC_OA_3.16-s7plus-rhel-0-28.x86_64 (snapshot)
           Requires: libminizip.so.1()(64bit)
           Requires: libgstreamer-1.0.so.0()(64bit)
           Requires: libgstvideo-1.0.so.0()(64bit)
           Requires: libgstbase-1.0.so.0()(64bit)
           Requires: libgstaudio-1.0.so.0()(64bit)
Error: Package: UTIL-WCCOA-SSEN-HV-1.0.0-1.noarch (snapshot)
           Requires: WkRt-Lin
           Requires: libdbus-1.so.3(LIBDBUS_1_3)(64bit)
           Requires: libgstpbutils-1.0.so.0()(64bit)
           Requires: libusb-1.0.so.0()(64bit)
Error: Package: WinCC_OA_3.16-sqldrivers-rhel-0-28.x86_64 (snapshot)
           Requires: libodbc.so.2()(64bit)
           Requires: libgstfft-1.0.so.0()(64bit)
           Requires: mesa-dri-drivers
           Requires: libgsttag-1.0.so.0()(64bit)
kilianvp
Re: WinCC OA RPMs and Dependencies
Post by kilianvp »
libminizip -> minizip http://rpm.pbone.net/info_idpl_55096597 ... 4.rpm.html
When I try to install WinCC OA via yum. It tries to download the following packages:
SDL gcc-c++ libXScrnSaver libstdc++-devel minizip postgresql-libs unixODBC
winthrop.polk
Yeah, I suspect that is for Ubuntu or something... I don't think the same packages are available for RH. We have to install minizip to get the missing dependency.
kilianvp
Post by kilianvp »
I clould install minizip without any problems using RHEL 7.
yum install minizip
minizip.x86_64 0:1.2.7-19.el7_9
winthrop.polk
I'm guessing you have non RH 7 standard repos configured or perhaps this was added recently because they froze our local repos years ago.... funny though, version 17 not 19 is what is needed for 3.16.
