In the new 3.11 SP1 package for Windows 64bit I'm missing the GMS ACTIVEX objects, previously to be installed under Third Party Software. I need them for a migration of a 3.10 project.
Does anybody have an idea what happened to the GMS stuff?
GMS ACTIVEX objects
Re: GMS ACTIVEX objects
The GMS ActiveX objects are only available on 32bit windows
the GMS ActiveX package (3rd party software) is only available as 32bit-version. Therefore it cannot be selected for the installation on a 64bit-system.
The WinCC OA standard objects which are using GMS-objects have been modified to work without these ActiveX elements.
- ewu01
Hi Mr. Knipp,
thanks for the clarification. Is this a loss of features without any notice in the release notes of V3.11?
Attached is a screenshot of 2 specially taylored linear gauges. Do you have an idea how how I could replace them with your standard objects? The standard slider does not allow any scale values.
Kind Regards
Uwe Behrens
Kind Regards
Uwe Behrens
the screenshot was not attached to the last posting.
Please try to add it again.
- ewu01
... sorry, next try ... https://www.winccoa.com/fileadmin/image ... liders.zip
- Attachments
- sliders.zip
- (7.15 KiB) Downloaded 259 times
if you want to have a new customized slider you can create a panel-reference with the following objects:
-- slider object
-- text for the minimum and maximum value
-- text for the current value which is changed when the slider is moved (event Change/Slide for the slider object)
-- the minimum/maximum value and tick interval is set with $-parameters which are defined when adding the reference to a panel
Another possibility would be the installation of 64bit ActiveX-elements or the creation of own objects (EWO).
How to build a EWO is described in the online-help: Graphics editor (GEDI) --> Complex graphics objects --> EWO (External Widget Object).
-- slider object
