Dear fellow WinCC-users,
I am asking for help with the following problem. What I basically want to do is the following: For a given project with readily set-up datapoint-types and datapoints (all float measured values) and archiving (100 ms), I would like to add a new archive with 15 minute average values.
When setting up archive compression (in system management, see attached pdf), I am only able to make new datapoint-types for which i can parameterize the compression mode.
Is there a possibility to do so for existing DP-types (as also shown in the pdf)?
As a further step, I would like to automatically delete the 100-ms-values once a month and only keep the 15-minute-values. Is that possible?
Thank you very much in advance for your help! https://www.winccoa.com/fileadmin/image ... rchive.pdf
Archive Problem (15 min average values)
- cpollak
- Attachments
- Archive.pdf
- (158.5 KiB) Downloaded 239 times
- fmulder
Re: Archive Problem (15 min average values)
Yes, both your questions can be answered with yes.
Assume you have a datapoint type with an element called 'Value'
* Add a new dp element called 'Value15' to your datapoint type
* Give this 'Value15' a statistical datapoint fucntion. Select average, a time of 15 minutes and select your previous element 'Value' as input. Your Value15 will now update every 15 minutes and will then display the 15 minute average of 'Value'
* Also, add an archive config to this element 'Value15'.
For your second question
* Asume 'value' is archived in 'archive1'
* Configure 'Value15' to be stored in a different archive
* Setup your first archive to be deleted after a month (example: change an archive every day, and only keep 30 archives)
Hope this helps. Good luck
Frenk
Frenk
- cpollak
Thank you very much for you fast response! I will have a look into it.
if you want to use compressed values (calculated by statistical functions) please use the standard naming convention for WinCC OA.
The compression levels get the the name C + number of level, e.g. C1, C2, C3 ....
The dp-element then gets the name for the statistical function, e.g. .AVG_WT0, MIN, MAX, .....
This has the advantage that WinCC OA standard functionality, which is using compression structures, can use this structures.
- fmulder
Yes, the standard functions will call it C1, C2, C3 etc..
However, it is no (technical) problem to define your own dp element (with your own name) and give it a statistical function.
Good luck
Frenk
Good luck
Frenk
- aorange
hmm here is a curve-ball, I have used both of these methods to achieve what the OP has asked for and would like to know which one is better from a performance point of view. Do they both use exactly 1 event per value update? which is better from a memory perspective?
I do not know which methods you are talking about.
For the calculation of statistical functions it does not make difference which names the dp-elements have.
