We've found a little problem using CSS properties on Embedded modules.
Currently, we're using a picture as background on the basePanel and the naviModule has to have a transparent background to be able to see the background picture.
There is no "Background color" property in the "Property editor" for the embedded modules so i tried using a CSS property "background-color: transparent;".
Now, both naviModule and mainModule are transparent but ... we are experiencing troubles with the background color of the tooltips and buttons.
They are black and we can't see the text.
if I remove the CSS property, it works normally.
Is there any solution to have transparent modules and visible tooltips / buttons ?
CSS prooerties and transparent backgrounds
- fmulder
Re: CSS prooerties and transparent backgrounds
Why not use 'addSymbol()' instead of using a module. A symbol has no background by itself.
Example:
You could add your whol process panel to a screen using addSymbol(). You could also remove it using removeSymbol().
Hope this helps you
Frenk
Example:
Hope this helps you
Frenk
- jfily
I can now reply with my account since it was approved by ETM.
Thank you for this function (I didn't know it exists, I just started with WinCC OA) but ...
When I use Panel Topology, it creates 3 modules :
- naviModule
- infoModule
- mainModule
I have to use embedded modules ...
I want to be able to see the background image set in the basePanel to avoid using several background images in my other modules.
- naviModule
- infoModule
- mainModule
- msuda
it is possible to set the background color of the loaded panels in the module transparent. Then you'll see the background of the main panel. And all Shapes of the loaded panel are normally visible.
I hope that this will help you.
Kind regards
Martin Suda
Kind regards
Martin Suda
- fmulder
I tried the module with a transparent background. But it doesn't make the module transparent ????
I've never seen a transparant module.
The panel toploogy is 'married' to the modulenames 'naviModule', 'mainModule' en 'infoModule'. When you step away from the standard topology buttons, then you'll have to make the entire navigation by yourself.
I do not use any of the topology buttons (But do use the sumalerst being generated by topology).
If you step away from the mdoules, then you could use the script function addsymbol() to build up a screen (instead of using 'RootPanelOnModule' ). This may give you greater flexibility but will take some work.
Frenk
Frenk
- jfily
Hi everybody and thank you for replying.
Never seen a module with transparent background before ? There it is ! Look at the picture I attached to this message.
I tried to root a transparent panel in a module, it doesn't work as expected (look at the picture).
In this test, tooltip text is okay in the first module but not in the second one.
I can't understand why ...
Link to the picture
Link to the picture
- fmulder
I see you are using the Qt stylesheets to set the transparancy of the module. AND you have set the background of the panel to transparant.
I didn't know that you could use Qt styling to do something like this.
Nice tip.
Can't help you with the tooltips !
Frenk
Nice tip.
Frenk
- jfily
I guess i'll have to code my own tooltip function and avoid using PUSH_BUTTON object.
- msuda
Have you tried to configure the tooltips also via Stylesheets?
This is an example of a tootip configuration in css
QToolTip
border: 1,5px solid darkgrey;
background: rgb(235,240,255);
padding: 3px;
border-radius: 3px;
opacity: 240;
QToolTip
padding: 3px;
border-radius: 3px;
opacity: 240;
- jfily
Thank you for this tip.
I tried it and this is the result : Result
Colors are working in the non transparent-background module but not the transparent one ...
WinCC OA help said
And also
WinCC OA help said
(wrong ... I just did it ...)The color and background colors of a tool tip cannot be set ...
And also
(I wrote it everywhere and still doesn't work ...)If a tooltip must be shown for a transparent frame inside the frame also, use the code this.fill="[solid]"; for the Initialize script of the frame.
