xmlrpc.ctl is missing in WINCCOA 3.12
rajkumar.krishnan
Post by rajkumar.krishnan »
In PVSS 3.9 we have a control file "xmlrpc.ctl" inside \\scripts folder which is missing in the current installation of WINCCOA 3.12 64 bit.. Is it replaced with any other new control file or removed completely in 3.12..
Anyone please reply.
Re: xmlrpc.ctl is missing in WINCCOA 3.12
the script xmlrpc.ctl was used for the Java-UI.
This functionality was removed from the product, therefore also the script was deleted.
Have you been using the Java-UI?
rajkumar.krishnan
Dear Leopold,
Thanks a lot for the information.
But is there any alternative we can use for the webclient. How we need to use it.
Regards,
Raj
which "webclient" are you talking about?
The script xmlrpc.ctl uses the standard CTRL-functions xmlrpcClient() and httpServer(). You can make your own script with these functions.
rajkumar.krishnan
Dear Leopold,
Right now we are using webclient_http.ctl file to launch the webclient for our project. But we are getting an message box while opening which i have attached for your reference.
Please let us know is it a standard message for WINCCOA or we need to configure anything to avoid this messagebox.
Thanks in advance.
Regards,
Raj Image
at your posting the attachment was missing.
Please send it again.
rajkumar.krishnan
Dear Leopold,
I tried to attach the image again for your refernce. In case if the image is not attached below is the message box content.
WinCC OA User Interface
There were errors during the setup of the secured connection to aaeinbr100749n.ww888.siemens.net:
The host name did not match any of the valid hosts for this certificate
The issuer certificate of a locally looked up certificate could not be found
The root CA certificate is not trusted for this purpose
No certificates could be verified
Continue ?
with Yes or No button.
Regards,
Raj Image
