RegEx
8 posts • Page 1 of 1
SudoBen
RegEx
Post by SudoBen »
Hello again,
i have run into another Problem:
I'm triing to filter DP Names that are hold in a dyn_string via dynPatternMatch.
The Names are always build up llike device__property_propertyOfProperty_....
I am trying to filter all properties of the first level that do NOT have child properties.
I supposed the Regex to be something like
"*Device_??_/[[:alpha:]/]+"
"*Device_??_[:alpha:]+"
"*Device_??[/a]+"
"*Device_??[a-zA-Z]+"
"*Device_??[/a]*"
But none of this works :(
So I have serious problems to figure out the right RegExp.
Folowing the help i looked up the regex syntax for unix commands (http://www.mkssoftware.com/docs/man5/re ... gexp.5.asp e.g.) .
Is there any more specific documentation how regular expressions are implemented in WOA?
(Or a RegEx that suits my Problem ;) )
Thanks in advance
Best regards
BK
mpoint
Re: RegEx
Post by mpoint »
I don't think dynPatternMatch() supports Regex. It's more like fnmatch() or "globbing".
EDIT:
It's probably easy to miss, but the online help says:
The asterisk "*" replaces any number of characters, the question mark "?" replaces any character, characters in square brackets one of the characters specified in brackets.
That's basically globbing.
SudoBen
Re: RegEx
Post by SudoBen »
Your'e right it behaves like gobbing,
but the help states (dynPatternMatch):
Under Linux, the same rules for pattern apply as those that apply in Linux command lines for addressing files: These rules can be retrieved with "man 5 regexp" on Linux computers.
What I need to find is a pattern that matches e.g. 3 digits and 4 chars.
Is that possible to archive with WOA? Or are * and ? the only supported wild cards (no character classes and complements available)?
SudoBen
Re: RegEx
Post by SudoBen »
Ok, i found a (not very elegant) way:
[abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ][abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ][1234567890][1234567890][1234567890][1234567890][1234567890]
:woohoo: :woohoo: :woohoo:
But maybe someone comes up with a better solution :unsure:
mpoint
Re: RegEx
Post by mpoint »
I'm pretty sure you can shorten it by using ranges, like "[a-zA-Z]" and "[0-9]".
SudoBen
Re: RegEx
Post by SudoBen »
Nope. Unfortunately not. :dry:
patternMatch("[a-z][a-z]","aa") //No Match
Like quantifiers
patternMatch("[a]{2}","aa") //No Match
It looks like only very basic expressions are recognized :unsure:
That would be hell of a nice enhancement in one of the upcoming Versions :laugh:
mpoint
Re: RegEx
Post by mpoint »
Here's an alternative: Since Ctrl is extensible, you can help yourself out regarding regex support.
I put together this little experimental Ctrl Extension last evening: https://github.com/mooware/CtrlRegex. It provides replacements for patternMatch() and dynPatternMatch() based on the QRegExp class from Qt. And the bonus is, it even supports real globbing if you specify the pattern type "wildcard".
SudoBen
Re: RegEx
Post by SudoBen »
Cool , nice one :)
Looking forward to give it a closer look.
