Panel position
vedadramovic
Panel position
Post by vedadramovic »
one of our Wincc OA clients (User interfaces) is running on video wall that has 15 display (5 x 3).
It opens 4 panels as 4 separate windows. One of them is stretching along 5 display, one along 3 displays and other two are shown on one display each.
All 4 panels are opened as different (separate) User Interfaces.
Is there a way to set exact starting position of each user interface (panel) on a such multi-monitor, so after a restart of a project (or loss of communication with server) the constellation of UIs remains the same as before the restart?
Best regards,
Vedad
Re: Panel position
With the '-m' option you can specify the position (and size) of the panel.
For example '-m vision ,+0+0' to open the panel on 0,0 and with size it is '-m vision ,1920x1080+0+0' .
vedadramovic
Re: Panel position
Thank you very much for a fast and effective help.
vedadramovic
Re: Panel position
i know this has been actual long time ago.
We have never succeeded to use this -m position option in our case (videowall). It seems that coordinates on video wall are different to those used in WinCC-OA.
Is there a way to display coordinates and size of "vision" so I can reuse it in start configuration -m?
There is a datapoint telling smart client to start panel/vision on last running position. Where is held this info about last position and size?
Often after restart of project or after communication loss our visions/panels does not start on last position.
I would like to position visions/panels on our wideo wall, save that config and use it in case our visions/panels start on wrong location.
Best regards,
Vedad
Re: Panel position
With the functions 'getScreenCount' and 'getScreenSize' you can retrieve the coordinates of your screens.
With the function 'panelPosition' you can get the coordinate of your panel.
vedadramovic
Re: Panel position
Thank you Gertjan very much,
I will give it a try.
Best regards,
Vedad
vedadramovic
Re: Panel position
I want to make an update of this thread and to write what worked for us.
We use WinCC OA v.3.12.
We needed to position panel (module) on a video wall that has 6 or more screens.
Following method of panel/module positioning '-m vision ,1920x1080+0+0' did not work for us. Was it because, windows makes some strange coordinate system in case of video wall or something else, I do not know.
What worked for us are two functions:
- panelPosition() - returns accurate coordinates of pane position, which I used to find out what are my desired coordinates.
- moveModule() - moves module to specified position on the screen.
Important think to mention is that functions panelPosition() and moveModule(), in our case, worked only inside of panel that I wanted to move.
Thanks for the help Gertjan.
