problems with the functiion printTable()
Schoetzke
Post by Schoetzke »
When i use the function printTable() with the config, like see the code in my thread, every white line is incorrect.
The grey lines are correct.
The grid arround the white lines is twice.
Does anyone know the error or no a solution???
"main()
 string bereich = COMBO_BOX1.selectedText();
  dyn_string d1,d2,d3;
  d2=makeDynString("");
  d1=makeDynString("\\\\left{Anlage:  Wasserversorgung der Stadt Dresden} \\\\right{\\\\page / \\\\numpages}",
                   "\\\\left{Betreiber DREWAG Stadtwerke GmbH}\\\\right{"+formatTime("%d.%m.%Y",getCurrentTime())+"}",
                   "\\\\center{Wartungsprotokoll  "+bereich+"}");
  d3 = makeDynString("");
  int     columnsType=PT_ALLCOLUMNS;
  dyn_int columns=makeDynInt();
  bool    fitToPage=true;
  bool    landscape=true;
  bool    gridLines=true;
  bool    gridBackground=true;
  dyn_int margin=makeDynInt( 20,20,20,20 );
  string  printerName="";
     printTable("TABLE1",
                TRUE,
                d1,
                d3,
                columnsType,
                columns,
                fitToPage,
                landscape,
                gridLines,
                gridBackground,
                margin,
                printerName);
https://www.winccoa.com/fileadmin/image ... sdruck.pdf
PVSS_Tabellen_Ausdruck.pdf
(20.79 KiB) Downloaded 352 times
Re: problems with the functiion printTable()
Hello Mr. Schoetzke,
please notice that the ETM Portal does not substitute the common PVSS/WinCC oA support.
Please refer to the common support to get an answer to your questions.
http://portal.etm.at/index.php?option=c ... =15&id=152
