Qt custom widgets
20 posts • Page 1 of 2
amitgolhani
Qt custom widgets
Post by amitgolhani »
I wanted to know whether custom widgets created using Qt community edition can be integrated in WinCC OA using API (EWO)? Also I would like to know whether widgets available in QWT can be integrated with WinCC OA?
Best Regards,
Amit Golhani
Re: Qt custom widgets
Technically it is possible to use the community edition to create WinCC OA EWOs. Legally there could be some limitations.
To use available Qt widgets you have to implement the EWO interface.
amitgolhani
Hello Gertjan,
Thanks! I wanted to do PoC first before considering commercial edition, so wanted to check whether any community edition widget will work on WinCC OA or not. Can you share some examples of EWO based on custom widgets?
Best Regards,
Amit Golhani
If you have the source code from any QWidget, you can use it as an EWO.
You can also use the community edition (they are identical in sourcecode with the commercial one, except that the commercial one has additional add-ons, which you do not need for an EWO).
You just need to be aware of the fact that on Linux we configure Qt to use a namespace and different library names, so that it does not conflict with the existing Qt libs from the distribution (we call configure with the options: -qtnamespace WinCC_OA -qtlibinfix WinCC_OA).
amitgolhani
Hello Martin,
Thanks for answering to my queries. Could you please share with me self learning material of EWO?
Best Regards,
Amit Golhani
You need knowledge in Qt and C++ as the basis.
Everything else is trivial: just look into the api directory of WinCC_OA and check the README.
You basically need to setup some env vars and run newEWO.sh to have a trivial EWO showing the basic idea.
EWO is really just a tiny wrapper around any QWidget
amitgolhani
Hello Martin,
Thanks! I will try to run sample EWO after installing community edition as per WinCC OA requirement.
Best Regards,
Amit Golhani
amitgolhani
Hello Martin,
Can I add 3D custom widget as an EWO with WinCC OA to meet 3D graphic requirement?
Best Regards,
Amit Golhani
yes, you can.
We did that in 3.13 with the BarChart3D EWO
amitgolhani
Thanks Martin. Whether BarChart3D EWO is based on Open GL? Please let me support 3D technology in WinCC OA.
