Hello !
I have Bit_condition datatype and MP with "_address" Power config.
Some data comes through Simatic Native S7 driver, the other - through OPC driver. How can I change Powerconfig "_address" for different data points with one type "Bit_Condition" ?
I need the availibility to set the "_address" config to "S7" for one part of datapoints and set the "_address" config to "OPC" for other part. Is it possible ?
Two drivers run simultaneously.
thanx
Two drivers on one config
Re: Two drivers on one config
in this case you can use the address powerconfig "free address". Then you can define for every instance an address for another driver type.
- Alexey_Podkolzin
Thank you very much, Leopold !
