here are some enhancements for the PARA which provide advanced filtering options.
This makes it possible to add master DPs to choose from.
All filters (f.i. ??123**, internal DP and now master DP) can be used for copying configs from the master to selected (filtered) DPs and in the DP delete dialog.
It is designed to version 3.11 and also tested under 3.12.
It can be used if you like. But no warranties ...
https://www.winccoa.com/fileadmin/image ... RA_zip.gif
zip-file can't be uploaded, please rename to *.zip
Please copy the files in a project fore testing - not in the WinCC OA path.
master DP selected, no filter (master + 4 DPs, 116 configs)
master DP selected, filtered by "Reservoir_2*" (master + 2 DPs, 58 configs)
You can also use the filter in the Delete dialog:
DP delete dialog, no filter (master + 4 DPs)
the DP delete dialog with placed filter, (master + 2 DPs)
Please enjoy
Best regards
Uwe Heinrich
Department ELBAS, Section Studies and Development
SIGNON Germany GmbH, Dresden
