I am using some device which communicates on Modbus protocol and provides information of some parameter in 5 byte, 6 byte & 8 byte. Please suggest data type which I should use for holding 5,6 & 8 byte information in WinCC OA. Also I need to multiply these information with some scaling factor (message conversion) and then plot trends and create reports using this information.
Best Regards,
Amit Golhani
Data type to hold 5,6 & 8 byte processed information
- amitgolhani
- amitgolhani
Re: Data type to hold 5,6 & 8 byte processed information
Please suggest any workaround to handle this issue.
Best Regards,
Amit Golhani
Best Regards,
Amit Golhani
I do not understand your question, so I am not able to help you.
