BACnet Network configuration
P3tran
Post by P3tran »
I am trying to configure a Bacnet IP driver on WinCC OA. The network is on the 192.168.1.x range .
I used Kepware to extract data from the network and the configuration was as seen on photo 1. I changed the config file and put a driver on the console (see attached). Then I configured a driver to talk to one of the controller on the network with ip 192.168.1.23. Unfortunately I could not see any response from the internal datapoints.
Could you please point me to the correct direction?
https://www.winccoa.com/fileadmin/image ... Bacnet.zip
Bacnet.zip
(1.05 MiB) Downloaded 201 times
Re: BACnet Network configuration
I have no experience with the bacnet driver, but in general you need to configure an input address config before the driver tries to create a connection to the device.
Something is wrong with the attached file, because I am not able to open it.
P3tran
Post by P3tran »
Thank you for your response. It works fine for me. I re-imported the zip file just in case.
I did the database point configuration but I did not have any telegraphs received on the driver data point.
