\'Database not opened in multi user mode or WCCILdatabg not yet started\'
8 posts • Page 1 of 1
lukedonovan
Post by lukedonovan »
I tried to export a DPE, and I got the following message:
'Database not opened in multi user mode or WCCILdatabg not yet started'
I've waited quite some time before trying the ASCII export, to ensure I was trying to quickly after project start, but to no avail.
Is there a way to force start WCCILdatabg?
I've waited quite a while before trying the ASCII manager.
It will elapse the full 30 minute demo timer, and the WCCILdatabg still hasnt started in the log.
Re: \'Database not opened in multi user mode or WCCILdatabg not yet started\'
'WCCILdatabg not yet started'. This happens when you start the Ascii manager too soon. When you start a project, then first check the LogViewer and check that the databg manager is running. You'll see a message when the databg has been started.
lukedonovan
Hi Frenk,
It doesnt seem to start before the 30 minute demo times out.
lukedonovan
It seems to stop immediatly after starting
WCCOAascii (0), 2016.04.06 09:22:32.416, PARAM,WARNING, 224, Security issue: Username or Password entry found in config file!
WCCOAascii (0), 2016.04.06 09:22:32.682, SYS, INFO, 1, Manager Start, PROJ, Capel_Dewi, V 3.14 - 3.14 platform Windows AMD64 linked at Feb 19 2016 21:47:03
WCCOAascii (0), 2016.04.06 09:22:32.682, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ STEPHENJENK7E38:4997
WCCOAascii (0), 2016.04.06 09:22:32.728, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ STEPHENJENK7E38 (::1)
WCCOAascii (1), 2016.04.06 09:22:33.118, SYS, INFO, 6, Initialization by Data Manager finished
WCCOAascii (1), 2016.04.06 09:22:33.118, SYS, INFO, 3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ STEPHENJENK7E38:4998
WCCOAascii (1), 2016.04.06 09:22:33.134, SYS, INFO, 4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ STEPHENJENK7E38 (::1)
WCCOAascii (1), 2016.04.06 09:22:33.150, SYS, INFO, 102, Waiting for user names/passwords
WCCOAascii (1), 2016.04.06 09:22:33.150, SYS, INFO, 103, User names/passwords initialized
WCCOAascii (1), 2016.04.06 09:22:33.212, SYS, INFO, 2, Manager Stop
Normally the databg should start 60 seconds (data config entry: waitTimeForBGStart) after the pmon gives the message "9/pmon, The project is up and running. Entering monitor mode". You should check if the pmon is in the monitoring mode.
if you want to export data the ASCII manager does not establish a connection to the data- and event-manager. Exporting data with the ASCII manager also works when the project is not running.
When doing an ASCII import the ASCII manager stops when the import is finished.
As we cannot see the options you have been using when starting the ASCII manager we cannot detect what you wanted to do.
lukedonovan
What options do you need to see to be able to assist?
It has always worked fine, we have upgraded to V3.14 and now it has stopped.
we need to see the options you have defined for the ASCII manager, e.g. -proj, -in, -out ....
The log message (given above) only show the information that the manager was started.
Have you started the ASCII manager in a command shell or using the WinCC OA console?
