Restoring the Raima database
willw
Post by willw »
I wanted to test restoring the Raima database from backup.
This is described in the v3.14 Help at System Management|Database|Online Backup|Restoring the data
The page describes stopping the project, removing the db/winccoa directory and then running
WCCOAui -n -p vision/restore.pnl
to start a panel to perform the backup.
This is where I run into trouble; nothing happens when I run this command. No panel is shown.
I have tried various things:
  • Changing to the project directory before issuing the command line.
  • Running the code from an elevated command prompt, or from a shortcut with "Run as administrator" checked.
  • Creating a C:\\Temp directory (suggested further down the help page).
None of these make any difference.
Any clues as to what I am missing, please?
Re: Restoring the Raima database
maybe the problem is that the "-proj " parameter was not used when starting the user interface.
Please add this parameter when starting a WinCC OA process from the command line.
Why do you want to restore the database?
Have you made a online backup before when the project was running?
willw
Post by willw »
Quite correct. Thanks for that. I was puzzled how the panel would deduce the context of the correct project, but had not thought to try the -proj param.
(I had missed the word 'console' in the help instructions item 3, plus the
looked to me like a complete command line, rather than the parameter string supplied to an entry in the WinCC OA console program.)
Two reasons:
  • I wanted to be confident in the procedure, so I know what to do should I need to undertake it in reality for our customer
  • I am evaluating ways of storing the whole project in git version control. I want to place sufficient files so that there is sufficient information in the git archive, given a copy of the WinCC OA installation software, it is possible to restore a project. The ASCII Manager is the obvious alternative, although it seems fiddly to operate. Perhaps this could be mitigated by saving configurations and calling its command line version from a script.
Obviously, whatever I do, the exported / backed up database will not tolerate merging, and have to be treated as an atomic entity.
