I know about "Comparison trend" functionality in Select trend view but it's not exactly what I need.
I'd like to have ability to add some time (X) axis on the same trend area to compare the data.
Maybe someone has any idea to make value comparison more clear?
Comparing DP values in the different periods
- Piterskiy
Re: Comparing DP values in the different periods
the trend widget only supports one time axis per trend area.
Your description is not very clear for me. Do you want to see two time axis in the same trend area?
- Piterskiy
Leopold Knipp wrote:
Yes. To compare the same DPs in the different time periods.Do you want to see two time axis in the same trend area?
as described in my previous posting the trend widget can currently only show one time axis per trend area.
You could fill use the 'curveValues' function of the trend to fill it with (modified) timestamps to get the values time aligned in the trend.
