When using the getFileNamesRev function with the paramiter FILTER_FILES the following message appears:
SYS, WARNING, 196, Illegal byte (0xFF) in UTF-8-encoded string, Codepoint::fromUtf8
getFileNamesRev(folder,"*.bak",FILTER_FILES);
What is the problem?
I have a problem with the function getFileNamesRev
- akim
Re: I have a problem with the function getFileNamesRev
Which version are you using on which OS ?
The problem you hit might have to do with non-ascii characters in the filenames you are reading, which
we probably already solved in 3.14
- akim
I use version 3.12 and Windows 7 OS. How can I solve my problem?
as Martin Koller has written the problem is maybe caused by special characters in the filenames.
Can you please check if the script works when addressing a directory where only one file exists, e.g. about.pnl.
What are the filenames for the directory where the problem occured?
- akim
This problem occurs when the file name contains the Russian Cyrillic.
I renamed these files. But it would be better to fix this bug.
Thanks for the help
Thanks for the help
