Importing external widget objects
zscriven
Post by zscriven »
I have found a pie chart template I like in QT.
What steps do I take to import this as an external widget object in OA? https://www.winccoa.com/fileadmin/image ... _in_QT.png
Re: Importing external widget objects
First step, in the API installation dir there is a README file.
Then use the script, e.g. /opt/WinCC_OA/3.14/api/newEWO.sh
to create an example EWO.
Have a look inside the created .cxx file, there are TODO comments which should give you a hint what you need to do.
You should be able to just use qmake and make to compile the example.
Note on Linux you need to have Qt self-compiled with a namespace since we need that to not conflict with the system delivered Qt libs
(e.g.: ./configure -qtnamespace WinCC_OA -qtlibinfix WinCC_OA -nomake examples -nomake demos -nomake docs)
zscriven
Post by zscriven »
If I didn't orignially install the api manager how can I do this after the fact? Will this cost additional licensing?
You don't install an api manager, you just install the api development possibility, which not only includes the feature to create your own manager
but also to develop different types of plugins, e.g. an EWO or a Ctrl-Extension.
The license shield file does not account for plugins.
Note: I'm not from sales, so I have no idea what your license agreement covers.
zscriven
Post by zscriven »
Thanks! Where do I download that at?
The api comes with our product. Qt comes from the Qt company: http://download.qt.io/archive/qt/5.5/5.5.0/
I found out that it's not needed to compile your own Qt on Linux since the namespace can just be given in the .pro file and you link against the libs we already deliver.
For this, add the following in your .pro file:
unix: DEFINES += "QT_LIBINFIX=WinCC_OA" "QT_NAMESPACE=WinCC_OA" QT_NO_VERSION_TAGGING
