Query on config _common
bergauer
Post by bergauer »
Hello
I'm looking for a query to get the description from data points similar to "SELECT '_common.._???' FROM 'MyDp1.*' WHERE '_alert_hdl.._active' NULL". I know about the function dpGetAllDescriptions() but unfortunately I'm using CERNs pvssjava-lib that doesn't support this functionality.
Can the chosen attribute "_???" be named? Or is there no possibility to do so?
Andreas Grob
Re: Query on config _common
the "_common" config is not a config like the other ones.
The information stored in the "_common" config is just displayed as config in the para module to be able to set the values.
To set/read information for this config you have to use the functions for it. Doing a dpSet/dpGet on the _common config is not possible as it has no attributes.
Therefore you cannot use this config in a query string.
