During project start- up we are getting the below warnings;
WCCILdata (0), 2017.03.13 15:45:23.417, PARAM,WARNING, 46, Attribute was not archived, ManagerInitialiserfillAckAH, Notification class not found - Standard class is being used
850XA0264.state.QERR:_alert_hdl.2 (Type: 0 Sys: 0 Dp: 100034071 El: 37 : _alert_hdl.2.0)
WCCILdata (0), 2017.03.13 15:45:23.417, IMPL, WARNING, 187, DP: 850XA0264.state.QERR:_alert_hdl: No gone alert between two came ones at 2017.03.03 12:51:53.832 and 2017.03.08 15:27:04.843, AlertAdministration, insertAlert
WCCILdata (0), 2017.03.13 15:45:23.417, IMPL, WARNING, 187, DP: 850XA0264.state.QERR:_alert_hdl: No gone alert between two came ones at 2017.03.08 15:27:04.843 and 2017.03.09 15:29:22.668, AlertAdministration, insertAlert
WCCILdata (0), 2017.03.13 15:45:23.417, IMPL, WARNING, 187, DP: 850XA0264.state.QERR:_alert_hdl: No gone alert between two came ones at 2017.03.09 15:29:22.668 and 2017.03.09 18:28:34.585, AlertAdministration, insertAlert
850XA0264.state.Q_ON_OFF:_alert_hdl.2 (Type: 0 Sys: 0 Dp: 100034071 El: 43 : _alert_hdl.2.0)
WCCILdata (0), 2017.03.13 15:45:23.418, PARAM,WARNING, 46, Attribute was not archived, ManagerInitialiserfillAckAH, Notification class not found - Standard class is being used
WCCILdata (0), 2017.03.13 15:45:23.418, IMPL, WARNING, 187, DP: 850XA0264.state.Q_ON_OFF:_alert_hdl: No gone alert between two came ones at 2017.03.03 08:14:17.329 and 2017.03.03 10:57:40.358, AlertAdministration, insertAlert
WCCILdata (0), 2017.03.13 15:45:23.418, IMPL, WARNING, 187, DP: 850XA0264.state.Q_ON_OFF:_alert_hdl: No gone alert between two came ones at 2017.03.03 10:57:40.358 and 2017.03.03 12:51:53.862, AlertAdministration, insertAlert
WCCILdata (0), 2017.03.13 15:45:23.418, IMPL, WARNING, 187, DP: 850XA0264.state.Q_ON_OFF:_alert_hdl: No gone alert between two came ones at 2017.03.03 12:51:53.862 and 2017.03.08 15:27:04.868, AlertAdministration, insertAlert
WCCILdata (0), 2017.03.13 15:45:23.419, PARAM,WARNING, 46, Attribute was not archived, ManagerInitialiserfillAckAH, Notification class not found - Standard class is being used
WCCILdata (0), 2017.03.13 15:45:23.419, IMPL, WARNING, 187, DP: 850XA0264.state.Q_ON_OFF:_alert_hdl: No gone alert between two came ones at 2017.03.08 15:27:04.868 and 2017.03.09 15:29:22.699, AlertAdministration, insertAlert
WCCILdata (0), 2017.03.13 15:45:23.419, IMPL, WARNING, 187, DP: 850XA0264.state.Q_ON_OFF:_alert_hdl: No gone alert between two came ones at 2017.03.09 15:29:22.699 and 2017.03.09 18:28:34.618, AlertAdministration, insertAlert
Please explain the reason .
During Project Startup
- rglock
Re: During Project Startup
please check the following FAQ's, where you will get the answers:
https://portal.etm.at/index.php?option= ... &Itemid=54
Rainer
Rainer
