I'm working at the moment on a multiple timezone application and I would like that all my clocks / alarms are using the server timezone and not the different UIs timezone.
This is quite easy to achieve with ULC UX (timezone parameter) however I have no clues how to do it for UI (I am running on windows). I am obviously looking for some option as I don't want to use any infinite loop converting my clock or any table loop converting my alarms timestamps.
Does someone have an idea for me?
Alexandre
Change timezone of UI
Re: Change timezone of UI
You could try it with the 'TZ' environment variable.
- adaneau
Hi Gertjan,
i got this tip from Dieter but it has no effect... I guess it is some linux only command
BR
Alex
BR
Alex
In Windows maybe you have to use a different string for setting the timezone compared to Linux.
The setenv function should also work in Windoiws in WinCC OA.
At the code for the HTTP-server a comment is written that on Windows the timezone string needs to exaclty 3 characters long.
Can you please try it again.
- adaneau
Hi Leo,
I actually tried this syntax from Http but still unsuccessful.
I also tried this documentation :
https://science.ksc.nasa.gov/software/w ... /3_1_4.htm
Still nothing.
I wonder if it is possible to impact the UI live? If setenv can be called in UI during RT? I tried to set and restart but not good neither. I will try to do it at login before displaying clock.
Thanks for help
Still nothing.
Thanks for help
- adaneau
Ok I succeed to make it works.
I need to make first the setenv, following windows standard sytax:
https://msdn.microsoft.com/en-us/librar ... s.60).aspx
And THEN do a getCurrentTime() to refresh all my clocks... i dont know if it's a bug or normal behavior :laugh:
