I want to integrate python script in WinCC OA as a extended library.
The main objective that I want to run python functionality in WinCC OA as a extended library. I am sure WinCC OA 3.15 version can do that. I have WinCC OA 3.15 version.
kindly provide me possible ways to do that.
Your timely feedback highly appreciated.
How to Use python script in WinCC OA as a extended library
- saurabhltts
Re: How to Use python script in WinCC OA as a extended library
You need to create a CTRL extension. Check the install/api directory and the README file.
There is a script called newWCCILCtrlExt.sh you can use to create
a template/example extension.
- saurabhltts
Do I need to create every function of python or is the file readily available?
Nothing regarding python is available.
Whatever you need from python must be implemented by you.
- vogler
what is your primary use case?
*) Do you have a Pyhton program which needs to have access to OA? (dpGet,dpSet,dpConnect,...)
*) Or is your main program OA (ctrl or ui) and you want to call some python code? (and pass data in/out)
regards,
Andreas
regards,
Andreas
- saurabhltts
my primary use case would be,
main program OA (ctrl or ui) and i want to call some python code? (and pass data in/out)
- vogler
I found "Jython", so i gave it a try to use this in a JavaManager... a bit strange solution, but it works.
maybe same can be done with the WinCC OA C# Manager and Python for .NET (http://pythonnet.sourceforge.net/readme.html)
a dpConnect to two datapoints, the summary is calculated with a python script which is executed by Jython in Java.
WCCOAjava1:2017.06.06 13:01:52.616 Main.lambda$run$0 INFO : --- HOTLINK BEG ---
WCCOAjava1:2017.06.06 13:01:52.617 Main.lambda$run$0 INFO : DpIdValueList: 2
WCCOAjava1:System1:ExampleDP_Arg1.:_online.._value: 1.0 [FloatVar]
WCCOAjava1:System1:ExampleDP_Arg2.:_online.._value: 2.0 [FloatVar]
WCCOAjava1:2017.06.06 13:01:52.617 Main.lambda$run$0 INFO : n1=1.0 n2=2.0
WCCOAjava1:2017.06.06 13:01:52.621 Main.lambda$run$0 INFO : result from python n3=3.0
WCCOAjava1:2017.06.06 13:01:52.622 Main.lambda$run$0 INFO : --- HOTLINK END ---
public void run() {
PythonInterpreter python = new PythonInterpreter();
JDebug.out.info("dpConnect...");
JDpConnect conn = JClient.dpConnect() // dpConnect in Java
.add("ExampleDP_Arg1.")
.add("ExampleDP_Arg2.")
.action((JDpHLGroup hotlink)->{
JDebug.out.info("--- HOTLINK BEG ---");
JDebug.out.info(hotlink.toString());
Double n1 = hotlink.getItem(0).getVariable().getFloatVar().getValue();
Double n2 = hotlink.getItem(1).getVariable().getFloatVar().getValue();
JDebug.out.info("n1="+n1+" n2="+n2);
python.set("number1", new PyFloat(n1));
python.set("number2", new PyFloat(n2));
python.exec("number3 = number1+number2"); // this is the very simple python script
PyObject n3 = python.get("number3");
JDebug.out.info("result from python n3="+n3);
JDebug.out.info("--- HOTLINK END ---");
.connect();
I'd be keen to know what python code you'd like to execute and why you do not use CTRL directly.
Are you using any special python libraries ?
Can you give an example, please ?
