dpCreate
AMRPatricio
dpCreate
Post by AMRPatricio »
I wonder if someone can give me some advice: I am using the dpCreate( called via button inside of a panel).
The dp is created as expected but the different _configs that are configured on the master did not appear on the dp that is created. If I go to the para and change any config on the master, then the configs are show in the dp.
Am I missing any step?
Thanks,
Antonio
Re: dpCreate
If you are using master datapoints and power configs you have to use dpCopy() to create a new instance with configs defined at the master datapoint.
dpCreate() only creates the datapoint without copying the configs.
