DNP3 configuration
jocinanand
DNP3 configuration
Post by jocinanand »
How to write the value for digital output to the PLC through DNP3 driver.And I can read the digital Input
Also need to Know the difference between Binary Output status and Binary command ?By that i need to Know which group need to be used to write the value
alug
Re: DNP3 configuration
Post by alug »
Hallo,
writing binary output is DNP3 is described in WinCC OA Online Help section
Driver->DNP3->Defining the peripheral address of DNP3 driver.
At the bottom there is a description of Control Rely Output Block ( CROB).
There are several option for this command therefore it looks quite complex.
In the simplest variant you need an uint DPE for the OpType (Subindex 0) and write the values 3 and 4 to it
for LATCH_ON and LATCH_OFF. All other subindices are optional.
The Binary Output Status can only be read. It is the Status of a Binary Command.
Andreas
jocinanand
Thanks for the reply,
Herewith I attached the screenshot for the config file that mentioned the linkAddress and still I am getting this error continuously
PARAM,SEVERE, 54, Unexpected state, Dnp3IDPOutstation, brmCallbackFcn, Outstation DNP3: The response to a request had IIN bits set indicating the command failed
SYS, SEVERE, 54, Unexpected state, Dnp3IDPOutstation, processIIN, IIN bit indicating parameter error set from outstation DNP3
PARAM,INFO, 0, , Dnp3IDPOutstation, processIIN, IIN bit indicating parameter error from outstation DNP3 gone
Please help me in this case
Thanks &Regards
jocin
alug
Post by alug »
Hallo,
which value do you write on the DPE with the output address.
If you want to set permanently you must write 3 (LATCH_ON) and 4 (LATCH_OFF).
If you want to write PULSE_ON (1) and PULSE_OFF(2) you have to specify the times
on the other subindex. Otherwise you get a "parameter error" for the command.
If it does not work send a screenshot of you address.
Andreas
jocinanand
Attached here the screeshot Image
alug
Post by alug »
Hallo,
the screenshot looks good.
You get the "parameter error" when you write a value 3 or 4 on the "open" DPE ?
Can you send a wireshark trace?
Andreas
